Damaged Plastics
hammo
I took my 2003 gasgas txt pro 250 for the first time last weekend , decided to try to learn to wheelie , the wheelies got bigger and bigger until eventually I flipped it and in the process snapped my back mudguard and seat unit , where can I get a full set of plastics from and how much will it cost , ? Cheers hammo
Im very sure the plastics and airbox will interchange from 2002 up to 2010.
The air box lower is quite cheap new http://www.splatshop.co.uk/gasgas-air-filter-box-lower-part.html.
The main reason they break is they are fixed with a couple of small screws so they just come apart and break in a flip, Somtimes they are siliconed together and that helps a bit.
The best thing to do is take them apart and use polyurethane sealer such as Tiger Seal to bond the 2 halves together, This will make them 10 times stronger and maybe you will only break the mudguard on the next flip.
