elliotsdaddy Posted November 17, 2014 Report Share Posted November 17, 2014 Evening all. I am in the middle of changing the kickstart spring on my 290. I'm following the very handy 'how to' courtesy of Splatshop, but I am having a little trouble re-assembling and I was hoping someone might have a handy trick up their sleeve. The issue is this......I have re-located the kickstart assembly with all new springs and washers into it's location, I have wound the assembly anti-clockwise until it pops back into place so the kickstart is located on it's stop where it should be. The problem I have is that when I attempt to slide the casing (with new gasket I might add) back over the kickstart shaft, if there is any movement off dead straight (which is difficult to avoid) the assembly pops back out of position. I am attempting this from side on. I know it'd be better to attempt it with the bike led down but I'm not sure it would make a hugh difference. Does anyone have any tips on how to re-fit the casing without disturbing the assembly or am I missing something obvious? Thanks in advance, Chris. Quote Link to comment Share on other sites More sharing options...
elliotsdaddy Posted November 18, 2014 Author Report Share Posted November 18, 2014 Panic over. All done...I just hope it doesn't explode into a thousand pieces when I kick it for the first time. Chris. Quote Link to comment Share on other sites More sharing options...
