Front & Rear Axle Parts Assembly Order Tl320'80
iconic558
Well just when you think you have done everything correctly during a strip down to help with the rebuild fate throws a spanner in the works.....like knocking over my temporary storage bench whilst parts are drying AND deleting strip down photos...doh!
I now have all the front and rear axle assembly parts all mixed up, I can seperate most of the parts (most!) and but their 'as built' order is also hopelessly lost.
Would anyone have a drawing/ photo of front and rear axle assemblies?
Many thanks
If all was as standard it's not difficult to sort out.
Rear, put axle in from brake side, then spacer with flat cut into it (so it can go all way forward and not foul brake anchor slot) through brake plate, hub, then top hat spacer which sits against bearing, then long alloy spacer, through swinging arm again.
Front only has one spacer from memory.
