iltakeafive Posted November 24, 2014 Report Share Posted November 24, 2014 What's the best oil to use in a 248 cota, anybody used ATF in the clutch? Quote Link to comment Share on other sites More sharing options...
chappo Posted November 24, 2014 Report Share Posted November 24, 2014 Hi Mat, This extract is taken from the 248 owners manual, it's 300 cc's , of each gearbox and clutch. Quantity 1 Motor Castrol super TT 3% mixture 2 Gearbox Supergras 451 SAE 90 C.C USA floz GB floz Every 2 or 3 races or similar 300 10 10.5 3 Clutch & primary drive SAE 10w30 300 10 10.5 4 Front suspension Hydrol 7 200 7.1 7.3 Per leg Dave. Ps did you have a look at the brake images I sent? 1 Quote Link to comment Share on other sites More sharing options...
iltakeafive Posted November 25, 2014 Author Report Share Posted November 25, 2014 Brilliant thank you dave. I've got loads of 20/50 multigrade and loads of atf that's why I wonderd about t atf,works great in my beamish. Yea mate I did, works out the front bar was on the back and vice versa. Brakes are shockingly bad. Front brake works but Is to the bars!! Maybe get them relined Cheers Mat Quote Link to comment Share on other sites More sharing options...
chappo Posted November 25, 2014 Report Share Posted November 25, 2014 I've got the EBC water grooved ones on mine and they're not brilliant, but been spoilt with disc brakes on the modern bikes. 30years ago I'd have thought they were great but in those days on a steep downhill wet section when they failed to bite and ended up an my rear end I'd just get back on, now it'd be end of the trial and a 4 hour Radox bath. Good luck with sorting her out. Dave. Quote Link to comment Share on other sites More sharing options...
