devo8 Posted December 2, 2014 Report Share Posted December 2, 2014 I found on my 2012 290 that the nipple in the Reed case leaked causing the fuel pump to not work correctly ( i.e. the mixture leaned out , which made the throttle like an on /off switch with not a lot of modulation.also it was a pain in the a** to start. the old nipple was cut down and drilled out and a new nipple fitted , after this was done the carb needle was dropped a couple off clicks as it was over fuelling, the bike is now a totally different machine so controllable . I have Chris at Splat shop to thank for diagnostic , Rob , how are you finding the 2015 300 compared to your 2012 290? Quote Link to comment Share on other sites More sharing options...
robdyson Posted December 17, 2014 Report Share Posted December 17, 2014 I found on my 2012 290 that the nipple in the Reed case leaked causing the fuel pump to not work correctly ( i.e. the mixture leaned out , which made the throttle like an on /off switch with not a lot of modulation.also it was a pain in the a** to start. the old nipple was cut down and drilled out and a new nipple fitted , after this was done the carb needle was dropped a couple off clicks as it was over fuelling, the bike is now a totally different machine so controllable . I have Chris at Splat shop to thank for diagnostic , Rob , how are you finding the 2015 300 compared to your 2012 290? The 300 is a completely different animal, takes a bit of getting used to, love the handling fact absolutely love it its an all rond imprd bike Quote Link to comment Share on other sites More sharing options...
robdyson Posted December 17, 2014 Report Share Posted December 17, 2014 improved even Quote Link to comment Share on other sites More sharing options...
