Raga Replica Ignition
gasgasboy
The 04 Raga does have a re-programmable ignition but you need some software and the leads to do it. It is a very simple process (if you have a laptop). There are 4 pre programmed settings to choose from all giving slightly different charachteristics.
As it happens i had an 04 Raga and i bought the gear to do it. It cost about
GasGasBoy, the programming effects the ignition advance curve. The changes are not super dramatic, but very noticable for sure. The mellower curves make for a much smoother, less abrupt power characteristic, particularly off the bottom. Here's a graph of the various curves for referance.
