beta boy Posted January 12, 2004 Report Share Posted January 12, 2004 when it is wet and muddy i go to start my bike and my foot slips off the kickstart and stabs me in the leg, ive tried cutting some grip into it with a saw but it doesn't help much. any tips on how to stop it from doing this Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted January 12, 2004 Report Share Posted January 12, 2004 Maybe some friction tape...like they put on hockey sticks. Great stuff. Quote Link to comment Share on other sites More sharing options...
pa. Posted January 12, 2004 Report Share Posted January 12, 2004 The 98 and 99 Kick Starter are cast with groves in them to stop this from happening and would bolt straight on. Uncle Charlie tip is cheaper though. Quote Link to comment Share on other sites More sharing options...
wayneg Posted January 12, 2004 Report Share Posted January 12, 2004 (edited) I put the alloy '99 Techno kickstart on my old '94 Techno - fitted straight on and worked a treat. It also has the advantage of being a bit longer so helped make starting less effort as well. Edited January 12, 2004 by wayneg Quote Link to comment Share on other sites More sharing options...
beta-boy Posted January 12, 2004 Report Share Posted January 12, 2004 i'de watch out for the feet slipping off the starter i've got a huge scar in my leg from slipping off the starter and putting the foot peg in to my leg on the way down not a pleasant experience, but since then i've learned to kick a bit more jently and be cautious when its wet out Quote Link to comment Share on other sites More sharing options...
ronm Posted January 12, 2004 Report Share Posted January 12, 2004 (edited) Some folks never seem to figure out the proper way to kickstart a motorcycle. You see them slamming at the lever to sort of get a running start at it, or trying to kick the bike through with the strength of their leg. This makes starting a Beta especially difficult since must of us are less coordinated on our left side. The best way to start the engine is as follows: 1- use the kickstart lever to bring the piston into the compression stroke 2- hoist your body upward using your right leg until your left leg is nearly straight. You can also use the bars and slight pressure on the left if needed, but not enough pressure on the kickstart lever to turn the engine over. 3- drop your weight onto your left foot/kick starter with a down and back pressure 4- If you loose your balance, dab with your right foot and start the process again. I really prefer the left side starter because sometimes if your engine comes uncranked, it is helpful to be able to hold the rear brake while restarting. I guess like most everything else, it is a matter of personal preference, but I really think that people who dislike the left side starter, just don't have the knack for it. This method ( reverse the feet) is also better for other makes as it reduced stress on the starting mechanism. Edited January 12, 2004 by RonM Quote Link to comment Share on other sites More sharing options...
beta boy Posted January 12, 2004 Author Report Share Posted January 12, 2004 thanks for the tips guys, i think ill get a new kick start where should i get it from and how much is it going to cost. Quote Link to comment Share on other sites More sharing options...
taff Posted January 12, 2004 Report Share Posted January 12, 2004 I just took an angle grinder to my 95 Techno's kick starter after I was sliding off it when wet. tapered the end out & made sure that I did it so that when close to the bottom there was a knob cut out at the end so that my foot wouldn't come off when at max pressure. Hope this sounds right. Or just get a 04 Rev3 like me & don't have these problems Taff Quote Link to comment Share on other sites More sharing options...
stuessenhigh Posted January 13, 2004 Report Share Posted January 13, 2004 Hi Beta Boy...Since you'll probably want it sent air-mail, I suggest trying www.bvm-moto.co.uk Speak to a guy called Laurence in the parts department (01453) 762 743 They regularly send parts out to me in Hong Kong, and have so far, been VERY reliable. GOOD luck.......and to all you cynics out there.....NO, I'm not on commision!!...I just think when you get good service (pretty rare these days)...shout it from the rooftops!!!!!!!! Quote Link to comment Share on other sites More sharing options...
jaylael Posted January 13, 2004 Report Share Posted January 13, 2004 I can't resist this chance to tell about our buddy Chester. He used to ride trials back in the 80s - 90s but he had two separate incidents involving Beta kick starting which certainly did not help his career. The last one was in 97 if I remember right. He was at the "Dabber" trial and was kicking that stubby little shift lever sized kickstarter and it popped back ferciously. The arm took a swipe at his calf which just cleared the top of his boot, ripping open an artery. Within ten seconds there was a two foot puddle of blood on the ground and it was spreading fast. The artery must have been pretty badly torn open. It was a legitimate threat to Chester's life! If not for quick thinking by the trials marshall's lovely parmedic wife, he probably would not have survived. She applied pressure to the wound with her bare hand and sent someone to call 9 1 1 . They showed up with a friggin' great big fire truck at the trials. Funny thing, ol' Chester don't ride trials anymore. Quote Link to comment Share on other sites More sharing options...
