1996 Beta Techno Brake And Clutch Levers
betatechnopilot
Hi, these will fit from Raceline on eBay Raceline Cast AJP Brake / Clutch Levers (GasGas, Beta, Scorpa, Montesa). Short levers.
To stop your levers snapping off, you need to adjust them so that when you pull in your front brake or clutch levers, the ball on the end of the lever is about 1.5 inches from the end of the handlebars.
Another way of explaining it is to adjust the position of the brake and clutch levers on the handlebars, so that when you extend your index fingers, they grab the end of the lever, just behind the ball on the end of the lever. Or, adjust the position to allow for two fingers to grip the levers, rather than having room for all four fingers on the lever.
So, you are moving the levers in towards the steering head
Edited by stpauls
