toetoe Posted December 10, 2014 Report Share Posted December 10, 2014 is a gas gas level when both tyres are on the floor or when the flat part of the bash plate is sitting on a stand. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted December 10, 2014 Report Share Posted December 10, 2014 Depends if the floors level ? What are you trying to do ? Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 10, 2014 Report Share Posted December 10, 2014 Come on Glen, check the oil ! Quote Link to comment Share on other sites More sharing options...
guys Posted December 10, 2014 Report Share Posted December 10, 2014 is a gas gas level when both tyres are on the floor or when the flat part of the bash plate is sitting on a stand. That's when. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted December 10, 2014 Report Share Posted December 10, 2014 (edited) Evening Ross ASSUME assumptions can make an ASS out of U and ME ! ☺ if its for the oil put 400ml in and then let it settle. I always just put 450 straight in but i leave it a while with the drain plug out. If you are using the window as a guide the bike needs to be on its wheels and perpendicular, you should be able to see oil with 400 in but try and get the window half full. Edited December 10, 2014 by baldilocks Quote Link to comment Share on other sites More sharing options...
toetoe Posted December 10, 2014 Author Report Share Posted December 10, 2014 yes i'v changed the oil, i ran it for about 5 minuets then let the old oil out, left it for a good 20 minuets so it was completely empty, i put 350ml in at first just to see where it came up to on the glass and it didn't even reach the bottom of it so i put the other 100ml in and it completely covered the glass, this is where i started to think about the level, i put a spirit level on the floor but then started to question when is the bike level, on it's wheels or on the bash plate, up off the floor, i know to some people it sounds a bit of a daft question but i couldn't find the answer so here i am. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted December 10, 2014 Report Share Posted December 10, 2014 Ok is the bike vertical ? Its ok as long as you havent put more than 450 in, just my view, but the manuals said 500 at one point and the engine hasn't really changed. The motor does have a breather to allow any over fill out on the left side. Leave it a couple of hours and it should settle. Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 10, 2014 Report Share Posted December 10, 2014 Leave you a couple of hours and you'll settle too ! Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted December 10, 2014 Report Share Posted December 10, 2014 Just on two wheels, with a level surface. Quote Link to comment Share on other sites More sharing options...
