New-To-Me Bike. New To Trials Riding
drbillz
Long time woods rider. Picked up an '09 2.9. Needed a small bit of work. Clutches stuck together. Timing off a little, leading to starting backward. Have a flywheel puller ordered to fix that problem hopefully. Other than that it's in good shape. Tight engine and wheel, suspension bearings, etc. Changed the tranny oil. Good deal on the bike for what it was. Now to have fun.
While you are doing the timing it's worth taking the small clutch cover off & pull the clutch plates out to free them up otherwise you'll need get the bike moving before getting it into gear then stand on the brake for a bit. It's a well known problem with a few brands of trials bikes when left sitting for a couple of weeks or so
Clutches can stick like chuck if left sit too long. Never trust them! I mean never!
At very least place the bike in 4th gear and sit on the bike rocking fore and aft with lever pulled in to break them loose prior to starting!
Never seen one run backwards either unless the woodruff key was sheared possibly, but who knows?!
If woodruff is ok and top mark on stator plate is aligned with top edge of case web, you likely need a stator plate.
