fanticsjj Posted December 16, 2014 Report Share Posted December 16, 2014 looking for any info on engine type ? i know originally it had a minarelli engine ! can i fit a 80cc air cooled mono engine ( with mounting mods ) or any other suggestions to get this back to where it should be thanks in advance steve Quote Link to comment Share on other sites More sharing options...
hendrik Posted December 17, 2014 Report Share Posted December 17, 2014 The rear mounting points are different, the mono swing arm spindel runs through the engine ( I hope you understand what I mean ) So the engine is to long or perhaps try to modify a mono swing arm in combination with the mono engine..... Quote Link to comment Share on other sites More sharing options...
hendrik Posted December 17, 2014 Report Share Posted December 17, 2014 You can also put a little Honda engine in the frame.... 1 Quote Link to comment Share on other sites More sharing options...
fanticsjj Posted December 17, 2014 Author Report Share Posted December 17, 2014 thanks for the reply i understand about the mono engine ! would a swing arm off another fantic twinshock fit ? ( one with a fantic engine ) if not which honda engine would you use ? Quote Link to comment Share on other sites More sharing options...
hendrik Posted December 18, 2014 Report Share Posted December 18, 2014 The 50/80 frame is smaller then the other twinshock fantics, so no other swingarm will fit. All small honda engines have nearly the same dimensions, easiest way will a TL 125, but also a XL185 is possible, take what you can get for little money 1 Quote Link to comment Share on other sites More sharing options...
ducman Posted December 18, 2014 Report Share Posted December 18, 2014 If you want to stay with a low capacity 2 stroke engine a 50,80 and 125 Sachs engine will nearly fit plug and play. 1 Quote Link to comment Share on other sites More sharing options...
andyrothers Posted December 18, 2014 Report Share Posted December 18, 2014 Did a similar conversion on an aprilia 50 trials a few years back and installed honda 125 ohc. All of the engine mounts had to be remade biggest problem was the height of the intake on the honda engine no room for the carb. Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 18, 2014 Report Share Posted December 18, 2014 Remember a lot of the cheap Chinese bikes have exact copies of honda engines and can be picked up for pennies. 1 Quote Link to comment Share on other sites More sharing options...
fanticsjj Posted December 18, 2014 Author Report Share Posted December 18, 2014 Thanks for the advice would prefer genuine honda engine but will see what I can get ! Will keep updating Quote Link to comment Share on other sites More sharing options...
tlrmark Posted December 19, 2014 Report Share Posted December 19, 2014 Remember a lot of the cheap Chinese bikes have exact copies of honda engines and can be picked up for pennies. I have some experience with these cheap Chinese Honda copy engines and they are truly worth pennies.Used genuine Honda 125 engines are cheap and common both in the u.k. and north America. 1 Quote Link to comment Share on other sites More sharing options...
fanticsjj Posted December 19, 2014 Author Report Share Posted December 19, 2014 Found a xr125 engine is that the same as the tl engine ? Quote Link to comment Share on other sites More sharing options...
tlrmark Posted December 19, 2014 Report Share Posted December 19, 2014 Never heard of a XR125 if it is a XL125 it will work fine. The 1979 and later XL125 is much better than the 1978 and earlier, has stronger k/s gears, electronic ignition, bigger valves, improved cam chain tensioner and a six speed transmission. The main difference between a TL125 engine is the first three gears are very close on the TL , and compression ratio 8.1 on TL, 9.1 on XL. An XL engine will work great, transmission ratios in the XL box are not an issue when the overall gearing is lowered for trials use. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted December 19, 2014 Report Share Posted December 19, 2014 XR is the enduro version and will be different to the TL but certainly won't be a ball of fire so it may be suitable for your needs. No doubt somebody will know the prime areas of difference. Quote Link to comment Share on other sites More sharing options...
axulsuv Posted December 20, 2014 Report Share Posted December 20, 2014 Now you guys got me thinking about the FM 330 50cc in my shop that needs a crank for the little minarelli ... I'm thinking a xr/sl 100 engine might just be the bomb for the little bike ... 'cause the chassis is so fun to toss about ... Glenn 1 Quote Link to comment Share on other sites More sharing options...
fanticsjj Posted December 20, 2014 Author Report Share Posted December 20, 2014 Hi Glenn I bought the frame off someone who bought a house and it was in the cellar thinking I would pick up a engine to fit and get it going but searching about realised its not a easy job ! Honda engine seems the way forward although all my bikes have been 2 strokes so know nothing about 4 strokes . I'm going to look at a engine on Sunday and I will post a picture as to size mountings etc once ive made any alterations then will get the frame powder coated ! Do u recommend any other frame mods before getting it coated ? Quote Link to comment Share on other sites More sharing options...
