Cleaning My Sherco
boner
Should be okay to lift the guard & use a strip of duct tape across the top of the airbox opening if you're talking about the older bikes with the tank & airbox in the conventional local
Haven't had much to do with the later bikes unfortunately
  On 12/20/2014 at 11:17 PM, ham2 said:
Never start it up after you've washed it until you've removed and dried the airbox internally.
And this applies specially to a simple hose wash, as you will dround it!
To be safer, pull mudguard and air filter, bung the filter hole with a closed cell foam block. Bung the exhaust outlet. Powerwash the hellofit!
Check your mag side cover for trapping water as well. If water gets in and cannot escape, that is not good. Put a 2-3mm drain hole in the bottom of it, it just works!
  On 12/21/2014 at 10:37 PM, billyt said:
Good name for a Texas rock band “Red Sticky Clay” :icon_salut:
title track would be "stuck in the red sticky stuff with you" or "i lost my gas gas in the clay pit" since i know a little about texas riders "hold my beer and i'll show you how it's done"(to the tune of devil went down to GA)
