Carb Leaking Fuel
imbeta
Hi guys,
I've got a '97 Techno 250 with what i think is a Mikuni VM26 carb. Ive only bought the bike a couple of months ago and I thought it would be wise to give the carb a good clean out with the compressor so i know where i'm up to with maintenance.
Ever since i've done that, every now and then it will p*** out fuel until i give it a persuasive tap with a nearby rock. The fuel is coming from the float chamber overflow pipe and its not trickling out, it's coming out as if the valve is fully open. (Which would suggest sunken floats rather than a dirty needle valve)
I've taken the carb apart again for a another clean, I checked the needle valve just to be sure (was immaculate), I took the floats out and submersed them in fuel to check for bubbles but they both seemed fine and checked for any resistance on the lever mechanism.
The only thing i did notice was on both floats there was a flat spot on the pin that is in contact with the lever so i twisted them round 180 with a pair of pliers.
Reassembled every thing and its still doing it!
Wanted to check if this was a common fault before i start replacing parts of the carb
Cheers!
Lyle
Thanks for all your quick and helpful responses! Im almost certain it has nothing to do with the needle valve or seat as the rate the fuel comes out at its like the valve is fully open. Also i have tried reattaching the carb to the fuel line with the float chamber removed and turning on the fuel tap to check the valve for leaks but nothing gets through. Unless the needle valve gets seized open enough to resist the floats from returning then that could be a possibility... however it showed no such sign of this when i was checking its movement.
Floats are definitely installed correctly as they have an obvious chamfer on the top side.
I will run through that carb set up tomorrow. Thanks bilks!
The Lampkins mod method seems pretty extreme but its an option.... Is this a manufacturing problem then?
That was actually normal. Some bikes p****d all over and some did not. I think the bike fix got too screwed up and I am not going to read it again. Billy Traynors fix was the most correct if is still in there.
Edited by lineaway
I re-posted old article here below :icon_salut:
Mikuni Carb Setup By Billy Traynor
The first area of urban legend is the two little brass outlets with the pink hoses attached. You may know these as the "over flow tubes".
In reality they are not overflow tubes. While they may allow fuel to escape from them that is not there sole purpose of design.
They are in fact atmospheric tubes.
The main purpose of these tubes is to allow the fuel to reach atmospheric pressure.
This means that when the pressure in the carb body (slide area) drops due to the negative pressure in the engine the atmosphere pushes (@ 14.7 PSI) on the fuel surface helping it go up the jets.
There are two adjustments on the float level.
1. The tangs set the fuel level.
2. The little tab sets the travel of the tangs.
The "brass tang" level should be set accordingly.
Remove the float bowl and slide. Place the carb on a flat surface. Get down to eye level with the carb body and you will see two towers sticking up. One tower is the main jet tower the other is the pilot jet tower. Due to casting imperfections I will not supply an actual measurement.
(This settings is visual and will vary from carb body to carb body that is why I will not supply an actual measurement)
The brass tangs should project itself to the extreme left hand top corner of the lower tower or pilot jet tower. This sets the float level.
We will now set the little tab that sticks out perpendicular on the brass tangs.
The purpose of this tab is to stop the actual travel of the tangs downwards.
This is important, as it will alleviate many anomalies once set correctly. One must know that the small pointed plunger that the brass tangs pushes up acts like a light switch. The gas is either on or off. With this in mind one need only have this plunger move enough to allow the gas to flow freely and then close when the tangs act upon it pushing up.
Think of this! When you land off a large rock the weight of the floats push quite rapidly down inside the float bowl. This is known as gravity. The extended movement of the floats downwards tends to do two things. It moves the floats way down inside the float bowl allowing more gas than needed and it also causes some of the excess gas to be pushed up into the jets and into the engine. It also if not set correctly allows the float tangs to travel down to far.
It is kind of like being inside a fast moving elevator and when it reaches this bottom it kind of makes you bend your knees. In other words the elevator has stopped but you are still going downwards.
So how do you set this travel tab?
Adjusting the travel tab on the carb will not stop the floats from going down but it will stop the float level tangs from traveling all the way down. This is important as the further they travel the more they are likely to stick.
With carb back on the table and the float tangs set to the previous mentioned setting (top left hand lower tower) you should be able to lift the float tangs about 1/16 NO MORE.
This bit of play allows the tangs to move away from the plunger jet safely. You will notice that the plunger jet has a springy feel to it. This is allows the float level tangs to still travel up and press continual against the plunger jet for a good seal. The first contact of this plunger will not necessarily close the plunger jet off that is why there is some additional travel afforded.
The bottom line is that if the gas is coming out of the atmospheric tubes (overflow tubes to you) then the gas level is way to high to begin with. It is not that they are not shutting off it is purely that they are set to high. Keep in mind we are taking about the bike in static upright position with or without the engine running.
The other thing I would highly suggest is that the pink hose ends be cut on a very sharp angle and small holes placed in the pink tubes. This will help alleviate the siphoning action if it does tend to flow out of the tubes. After all the levels and tangs are set correctly. There is still the possibility that gas will come out of the tubes in some rare circumstances. By cutting the ends of the tubes on a very sharp angle and piercing small holes into the tubes that siphoning action is somewhat cut off. This siphoning action can even after the floats have settled down keep it self self-going.
Also you should withdraw the pivot pin (the pin the float level pivots on) about 3/8 of an inch and pinch it with some side cutters about 1/8 on an inch from one end and then slide/push it back in. This notched pin will help it stay put in its housing.
These pins tend to vibrate out and hit against the side of the float bowl (look at the inside of the float bowl for witness marks to this happening).
One other area of concern on the Beta is the two vent hoses coming out of the engine are far to near the float bowl. In fact mine were pushing against the float bowl this caused excess vibration into the carb body, which in turn plays havoc with the float levels.
I solved this by cutting the cable tie and having them go around the carb float bowl.
Ah okay well that would explain why the tubes were so short. When it p****d out fuel the first time i extended the hoses down below the bike so it didn't get covered in fuel. But if they're atmospheric tubes and not overflow then they shouldn't have fuel coming out of them. Extending the hoses below the float chamber could actually be syphoning out the fuel!
According to this picture and, by the sounds of it, Billy's set up, they have set the brass tangs to run diagonally upwards by bending the tab down towards the needle valve whereas mine are parallel to the plate below that you can just about see...
Will have a play around with it today and see what i can do. Thanks to everyone for all the support so far! :-D
Edited by imbeta
