bengrainger1985 Posted December 25, 2014 Report Share Posted December 25, 2014 Hi all when you push the bike it makes a grinding noise sounds like its coming from the front sprocket area any help would be much appreciated only been on it once Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted December 25, 2014 Report Share Posted December 25, 2014 is it free from debris , is chain good and lubed ,tensioner in line ? and if not the brake it sounds like it could be a bad bearing in gearbox Quote Link to comment Share on other sites More sharing options...
bengrainger1985 Posted December 25, 2014 Author Report Share Posted December 25, 2014 The chain and sprockets are new every thinks clean wheels straight hope it is a bearing there's a lot of cogs in there and it could be expensive if ones lost some teeth I was in the middle of the woods when I noticed and had to push it half a mile back to the van fingers crossed Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted December 25, 2014 Report Share Posted December 25, 2014 what did you notice that made you push it Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 25, 2014 Report Share Posted December 25, 2014 What type of chain was used? New rear Tire? (Brand) Quote Link to comment Share on other sites More sharing options...
bengrainger1985 Posted December 26, 2014 Author Report Share Posted December 26, 2014 The rear wheel bearing collapsed sprocket side making the chain slack so started pushing it then heard the noise its not constant it dose it like every half rotation of the wheel Quote Link to comment Share on other sites More sharing options...
burns1989 Posted December 26, 2014 Report Share Posted December 26, 2014 U may find the chain is catching the frame if a bearing goes I would have thought it would be rough at full rotation . Take the chain off and rotate the front sprocket and make sure it rotates smoothly there will be a slight big of resistance but should feel the same all the way round . Chech for play as well up and down not in and out as the shaft does move in and out abit . Quote Link to comment Share on other sites More sharing options...
bengrainger1985 Posted December 26, 2014 Author Report Share Posted December 26, 2014 The engines nearly out of the bike now there is no play up or down the sprocket is notchy when you turn it and makes a clicking sound Quote Link to comment Share on other sites More sharing options...
burns1989 Posted December 26, 2014 Report Share Posted December 26, 2014 Ok could be in between gears . Pull out the seal behind the sprocket and see if there is any isues with the bearing . But I gues a full strip down is called for . You could be unlucky and have some gear isues or a bush has gone hard to tell with out seeing it. Good luck Quote Link to comment Share on other sites More sharing options...
liviob Posted December 30, 2014 Report Share Posted December 30, 2014 Maybe you rode the bike with the chain set too tight and destroyed the bearings in the wheel and counter shaft? Quote Link to comment Share on other sites More sharing options...
