Rev 3 125Cc Dellorto Flatside Float Height?
steve
Hi all,
Pretty much as the title says really - can anyone give me the float height for a dellorto flatside carb fitted to a 125cc 2006 Rev 3?
We are having problems starting the bike and when checking the carb the brass arms that the floats sit on were bent unevenly. The bike will sometimes fire first kick then refuse to start.
So you have a Del PHBH flatslide on a 125 Beta? I had no ides they put them there. Is it a 26 of 28?
Typacally the Del float arms are set level with the bowl surface when inverted. Cannot recall the actual measure. There was some setup hints and tips on the Splatshop Blog site or you might ring them.
