burns1989 Posted December 31, 2014 Report Share Posted December 31, 2014 Hi all went out today for the first time with the weight on and I must say I can see where the benefits are and where the cons are . And to be fair I don't like the way it makes it less snappy and run on alot and not switch off when I want it to I got caught out with this. But the only benefit id say is if u are climbing hills it's good for sure but that's it . So it comming off and into the tool box ready for any hilly sections . Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted January 1, 2015 Report Share Posted January 1, 2015 250 or 290? Quote Link to comment Share on other sites More sharing options...
burns1989 Posted January 1, 2015 Author Report Share Posted January 1, 2015 250 06 rev Quote Link to comment Share on other sites More sharing options...
liviob Posted January 1, 2015 Report Share Posted January 1, 2015 I have a 01 Rev 250 and i ended up removing the clutch side flywheel weight. Its behind the water pump. The 250 is pretty smooth even with no extra flywheel weight on the crank. Great bike! Quote Link to comment Share on other sites More sharing options...
burns1989 Posted January 2, 2015 Author Report Share Posted January 2, 2015 Yha i think it is smooth but the extra weight gives you too much torque and too much of one thing doesn't make for a better out come . I like the snappy power and quick shut off of the engine. I can see why people don't bother with the weights can't see how it make it easer to ride technicaly or learn to ride with . Quote Link to comment Share on other sites More sharing options...
dan williams Posted January 2, 2015 Report Share Posted January 2, 2015 (edited) Go for carbon fiber reeds. Makes the bike grunt up hills and smooths the power out quite nicely. Of course proper jetting is essential as well. Edited January 2, 2015 by dan williams Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted January 3, 2015 Report Share Posted January 3, 2015 ditch the weight you shouldnt need it on a 250 i found it makes it run on much too much Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted January 3, 2015 Report Share Posted January 3, 2015 as above qiuck shut off is probably more important Quote Link to comment Share on other sites More sharing options...
burns1989 Posted January 3, 2015 Author Report Share Posted January 3, 2015 Well its off tomorrow as u prefers it with out . It rides so much better with out the weight and responds to me as if I was part of the bike . 1 Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted January 3, 2015 Report Share Posted January 3, 2015 be careful with screws they can round off very easily, impact driver is best. 1 Quote Link to comment Share on other sites More sharing options...
