06 Montesa 4Rt Footpeg Hangers
scoobie232
Some help required on the topic of replacement hangers for my 06 4rt the originals are many times bent and reshaped, blob welded and releveled,
Opinions vary and have changed over the last five years or So reading through the related posts on here,
Titanium now questionable due to reported frame damage, billet alli good or or bad ?! steel/ original hangers ?.
Any Input on replacing these well worn hangers would be most appreciated.
Thanks.
I use standard mont hangers buy with a small 10mm rod welded to strengthen the bracket as per the ones on the future web site. Maintains standard position so no need for short brake pedal, can easily be welded and straightened if necessary and at about £20 each cheapest option
Thanks for chiping in guys where would I get either the standard or the repsol hangers ?,
Looked on the sandifords web site and saw steel hangers for a 315 for about £18 a side but the 4rt hangers were showing at about £63 + a side
That can't be right
That can't be right
I pretty sure the 315 hangers won't fit a 4rt (but I maybe wrong) so check before you buy ;0)
