davet Posted January 4, 2015 Report Share Posted January 4, 2015 Looking for any tips on re packing exhaust 2014 gasser . Cheers. Quote Link to comment Share on other sites More sharing options...
shercoben12 Posted January 4, 2015 Report Share Posted January 4, 2015 simple. just remove the bolts holding the end can on. then take out all the old stuff and repack with either stringy or flat sheet packing around the baffle and re build. welcome back to nice soft quiet power and tourque Quote Link to comment Share on other sites More sharing options...
davel Posted January 4, 2015 Report Share Posted January 4, 2015 Did mine about a month ago. Really simple, had no problems, just undid the bolts, pulled out the oily old stuff and shoved some new stuff in with the long bar from my socket set. Quote Link to comment Share on other sites More sharing options...
vmeldrew Posted January 5, 2015 Report Share Posted January 5, 2015 I did mine a few months back, swore never to touch the string stuff again, a complete pain for the non patient. The original packing was sheet and seems the logical replacement. Made hell of a difference though,. Quote Link to comment Share on other sites More sharing options...
tahoebrian5 Posted January 13, 2015 Report Share Posted January 13, 2015 This is on my to do list. I might have to tackle the middle box surgery as well. I'm leaking spooge out of a craked weld at the hanger at the top of the middle box. Also it seems to burn for a bit even after I shut off the engine. I imagine it's in fairly bad shape after 5 years of use. Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted January 14, 2015 Report Share Posted January 14, 2015 I repack mine once a year. It usually burns away. I also perform the annual surgery on the center box. I crash enough to make it necessary. the 14 center box is much more robust. Your tip: With the system gutted prewrap the inner pipe with packing and install it as an assembly. Wrapping it externally with mechanics wire also helps. I should really be getting mine done this week. Thanks for the reminder --Biff Quote Link to comment Share on other sites More sharing options...
trialtrial Posted January 27, 2015 Report Share Posted January 27, 2015 Hmm, The repacking has a few tricks to it. Just completed another one a couple of days ago. (1) very tightly wrap the packing and put three wraps of masking tape on it - holding it tight. (2) insert the wrapped in the muffler first - it will be easier to align with the pipe way down the muffler without the plastic muffler tip on. (3) Once properly inserted into the muff, and sitting properly on the pipe, then put on the plastic end piece. A flashlight will help you align it. (4) Gently move the tail pice up and down to align it with the pipe - do not force. Then have a couple of beer. 1 Quote Link to comment Share on other sites More sharing options...
Canario Posted August 26, 2019 Report Share Posted August 26, 2019 Does someone know the diameter and needed length of the rivets? Thanks! Quote Link to comment Share on other sites More sharing options...
doctorchopper Posted August 27, 2019 Report Share Posted August 27, 2019 I bought a set of pre cut ones from splat shop, hoping it will make the job easier https://www.splatshop.co.uk/jitsie-exhaust-silencer-packing-gas-gas-11-15.html Quote Link to comment Share on other sites More sharing options...
