zazoo Posted January 5, 2015 Report Share Posted January 5, 2015 I am going insane! I just took apart my carb for the 5000 th time, because I am having real problems starting the bike after a rebuild. Would you believe it, noticed on the side it is Dellorto PHBL 26 and not 25 as stated in the manual. Took the digital calipers to it, in case it was my eyesight and it is 26mm intake. My question is, will this make a massive amount of difference and is this the source of all my woes. Please help, someone please. The men in the white coats are coming. Quote Link to comment Share on other sites More sharing options...
lineaway Posted January 5, 2015 Report Share Posted January 5, 2015 No, it should work. Did the bike run before the rebuild? Quote Link to comment Share on other sites More sharing options...
zazoo Posted January 5, 2015 Author Report Share Posted January 5, 2015 No it was a basket case. Has a very strong spark though. Quote Link to comment Share on other sites More sharing options...
lineaway Posted January 5, 2015 Report Share Posted January 5, 2015 Compression, spark and fuel is all you really need. Does the slide close all the way? (I have seen them in backwards) Quote Link to comment Share on other sites More sharing options...
lineaway Posted January 5, 2015 Report Share Posted January 5, 2015 Is the plug wet with fuel, or you could put a little premix in the plug hole to bypass the carb. Quote Link to comment Share on other sites More sharing options...
lbhbul Posted January 5, 2015 Report Share Posted January 5, 2015 Had a problem similar w/Dellorto PHBL, was not fully applying choke lever. (rich mixture device) Luck; Larry Quote Link to comment Share on other sites More sharing options...
furse Posted January 5, 2015 Report Share Posted January 5, 2015 Check flywheel key, they snap if you haven't tourqued the flywheel past what you would think was tight, it will still spark some times Quote Link to comment Share on other sites More sharing options...
zazoo Posted January 6, 2015 Author Report Share Posted January 6, 2015 Yes the slide has full movement, but the plug has been wet when inspected. Quote Link to comment Share on other sites More sharing options...
lineaway Posted January 6, 2015 Report Share Posted January 6, 2015 So if the plug is too wet it will not spark. In that case it is flooded on the lower end and needs cleared out. Quote Link to comment Share on other sites More sharing options...
zazoo Posted January 6, 2015 Author Report Share Posted January 6, 2015 Thanks for that, but why do you think it is flooding? Quote Link to comment Share on other sites More sharing options...
boghog Posted January 7, 2015 Report Share Posted January 7, 2015 I had a very similar problem with a 200 which i restored last year , just could not get it to run right, messed about with the carb for what seemed an eternity. If the carb is original it is likely that the slide is worn along with carb barrel, so impossible to set up. In the end i ordered a new carb off Bill Pye at Frankfield Fantic which came correctly jetted and setup . Fitted it to bike and fired up 2nd kick never missed abeat since. Give Bill a phone he is a very helpfull. Quote Link to comment Share on other sites More sharing options...
zazoo Posted January 13, 2015 Author Report Share Posted January 13, 2015 Thanks for all replies. Took the carb apart again after having the petrol tap on and the float bowl was dry this time. Fiddled about with it again and put it back together. Kicked it over and thought there is something not right about this kick start. Drained the oil took clutch cover off. Noticed that the return mechanism stop was wrong side of the holding pin that screws in from the underside. Corrected this (very fiddly) and refilled oil. Kicked it over and sprang into life first kick. Running very nice indeed. ( for the time being) Quote Link to comment Share on other sites More sharing options...
totalshell Posted January 13, 2015 Report Share Posted January 13, 2015 sorting out that kick start spring is definately a three handed job Quote Link to comment Share on other sites More sharing options...
