magsy Posted January 11, 2015 Report Share Posted January 11, 2015 Hi can anyone tell me if theres a knack to refitting the airbox on this bike. Its only as I've had to remove the carb several times recently that its become a real pain. There must be an easier way than grappling for ten minutes with a screw driver. In the end I removed the fuel tank which gave me much more room. I know manufacturers are looking for new ways to improve there products but this to me is a part that needs to be removed often and so should be much simpler to fit. Any thoughts most welcome. Quote Link to comment Share on other sites More sharing options...
deanogasgas Posted January 11, 2015 Report Share Posted January 11, 2015 I struggled at first with my 2012st...slightly loosen the jubilee clip on the inlet side of the carb and slot the right hand side of the air box in first and be patient. then tighten both clips up. It is a bit of a chew. Quote Link to comment Share on other sites More sharing options...
slickgolf_0 Posted January 11, 2015 Report Share Posted January 11, 2015 Fit the carb to the airbox first then pop the carb back in , Quote Link to comment Share on other sites More sharing options...
copemech Posted January 12, 2015 Report Share Posted January 12, 2015 Just be glad you do not have a 250 with dellorto and the rubber reducer ring. Quote Link to comment Share on other sites More sharing options...
deanogasgas Posted January 12, 2015 Report Share Posted January 12, 2015 Yip air box first then carb, make shure you get the carb right in. Quote Link to comment Share on other sites More sharing options...
magsy Posted January 12, 2015 Author Report Share Posted January 12, 2015 Ok thanks, will try the airbox first method next time to see if thats a little easier. Quote Link to comment Share on other sites More sharing options...
ikb Posted April 15, 2015 Report Share Posted April 15, 2015 Just be glad you do not have a 250 with dellorto and the rubber reducer ring. Ant idea which way the rubber reducing ring should go? I guess the alignment mark at the top facing away from the carb! Quote Link to comment Share on other sites More sharing options...
