deanogasgas Posted January 12, 2015 Report Share Posted January 12, 2015 Hi, Can any one point me in the right direction on my fan not kicking in, Is there a procedure on what to do first. All wires are connected. Is there only 3 things Fan, rectifier, thermostat. Thanks Deano. Quote Link to comment Share on other sites More sharing options...
magsy Posted January 12, 2015 Report Share Posted January 12, 2015 Hi, what you can do and it worked ok on my sons beta is to link out the two wires connected to the thermostat. This basically makes the switch and the fan should come on straight away. If it doesn't then its not the stat and is probably the fan. If it is the stat my sons beta stat was about £20. Regards Magsy Quote Link to comment Share on other sites More sharing options...
deanogasgas Posted January 12, 2015 Author Report Share Posted January 12, 2015 Thanks Magsy, will give it ago, This wont cause any other wiring failures, This is just making a switch yeh. Quote Link to comment Share on other sites More sharing options...
magsy Posted January 12, 2015 Report Share Posted January 12, 2015 Yep, I use this method all the time when repairing boilers to rule out dodgy stats and sensors. Its only making a connection and switching power to the fan. Quote Link to comment Share on other sites More sharing options...
deanogasgas Posted January 12, 2015 Author Report Share Posted January 12, 2015 OK, Thanks for your help. Quote Link to comment Share on other sites More sharing options...
tony27 Posted January 12, 2015 Report Share Posted January 12, 2015 It's standard for most of the guys who I have trailridden on trials bike with to carry a piece of wire with terminals on both ends for bypassing the thermoswitch in the event of a failure The second the bike is running the fan will run which in theory makes the engine take longer to reach operating temperature but in reality I've never noticed any real difference in how the bike runs with the thermoswitch bypassed Quote Link to comment Share on other sites More sharing options...
deanogasgas Posted January 13, 2015 Author Report Share Posted January 13, 2015 Just to say, Thanks all for the help locating my problem. It was the thermostat... Cheers Deano. Quote Link to comment Share on other sites More sharing options...
