Trials Cub Shocks
bambam_n_chunx
I`ve just about finished rebuilding my cub, just need to sort the rear shocks and ignition system.
I`ve 2 questions
What length shocks will I need?
Its currently fitted with a capacitor type ignition which seems to be working well, so should I replace it with an electric ignition?
Which ignition is best? as there are 2 types, one which bolts straight in and one which needs posts machining onto the crank case.
Thanks for any help.
Just built a cub last year It had a distributor fitted I used Electicworld( in the basket case of parts) that fitted on to the outer clutch case which made life difficult to time the spark because when you put the case on you cannot see the timing marks The other crank case I bought have the pegs fitted and behind the clutch mod The units I fitted came off another cub and are 14" Rear subframe had mods done before I got it and has pins at the top mount
Edited by naichuff
