the addict Posted February 2, 2015 Report Share Posted February 2, 2015 On 2/1/2015 at 12:21 PM, hrmad said: standard is 11/42, I've got 11/44 on there. I'll live with it a bit and try slowing the bike down with the clutch if needed in sections. I can't blame the bike for poor technique 10/40 is the same as 11/44, if you want to lower it more stick the standard 42 on the back. As Betabonkers said, 9 is too small for the front, bigger on the back is a better way to go. Quote Link to comment Share on other sites More sharing options...
hrmad Posted February 2, 2015 Author Report Share Posted February 2, 2015 (edited) On 2/2/2015 at 9:08 PM, dan williams said: ...but you can pump it up again yes? That sounds like a leak in the system. I'd try a rebuild kit for the master cylinder first. On an older bike they're usually due for replacement. Before you do though make sure your bleeder valve is snugged properly as that can bleed pressure too. Yes. Will do on the master cylinder front when I get paid, thanks On 2/2/2015 at 9:20 PM, the addict said: 10/40 is the same as 11/44, if you want to lower it more stick the standard 42 on the back. As Betabonkers said, 9 is too small for the front, bigger on the back is a better way to go. I went back to 10/44 today from 11/44, much better, I've fiddled with it enough. I'm not going to go to 9/52 as I was advised on the training day, too low for the 200 I reckon. I know some people say that 10/44 is too low, but I'm sure it will be fine for my beginner level. It also brings 2nd, 3rd and 4th gear into play. I'm happy with the gearing like this, and if I need more momentum I can always go up a gear this way. I spent 30 quid on the 44, I haven't got the change to spend on a 42. Edited February 2, 2015 by hrmad 1 Quote Link to comment Share on other sites More sharing options...
hrmad Posted February 4, 2015 Author Report Share Posted February 4, 2015 Adjusted the lever where it presses into brake, if that makes sense. Worked fine today, though I didn't use it heavily on mud. Quick action throttle is awesome, you can really rev the bike and fire it up hills and blast through mud. Really enjoying it, much nicer to ride in that way. Thanks again 1 Quote Link to comment Share on other sites More sharing options...
