Tr280I Footpeg Removal
ric h
Hi Ric
If there the same as the 2012 ? Put a torx wrench in both sides of the mounting bolt and undo in a anti-clocwise direction,, the underside bolt should come out, then from underneath tap upwards with a drift or pin punch and the top shaft will come out, this has a 8mm female thread in it.
Yes it's a bazar way of fixing pegs (unlike everyone else) BUT the pegs dont seem to wear on the shaft much as there a 10mm dia rather than 8mm like all the others.
Hope this helps.
