jefgil123 Posted January 23, 2015 Report Share Posted January 23, 2015 (edited) Anybody have the chain fall off and break the rear case boss that the mag cover screws onto? Am I better off cutting off that lug on the left center case before that happens ? Or is a case saver plate the way to go? Thanks, Jeff Edited January 23, 2015 by jefgil123 Quote Link to comment Share on other sites More sharing options...
dadof2 Posted January 23, 2015 Report Share Posted January 23, 2015 The case saver plates don't always work, the chain can come round the sproket in 2 layers and exert so much force it rips the plate mount out of the top of the gearbox. Fortunately the crankcase is weldable. What seems to be best is an extended swinging arm protector that "peels" the chain off the sprocket. Quote Link to comment Share on other sites More sharing options...
jefgil123 Posted January 23, 2015 Author Report Share Posted January 23, 2015 Do you mean, to keep the chain running back and out, towards the chain tensionser arm and out the back ? I can visualize that then the chain won't wind up, and around the sprocket. Thanks, Jeff Quote Link to comment Share on other sites More sharing options...
