hughandjen Posted January 27, 2015 Report Share Posted January 27, 2015 Hi guys Where would I get a new condenser from as going to fit it under the tank It's a 1970s Cora 247 Thanks Quote Link to comment Share on other sites More sharing options...
kingscorpion Posted January 27, 2015 Report Share Posted January 27, 2015 I know it's written in spanish, but Google translator can be of help. http://montesakingscorpion.blogspot.com.es/2011/11/condensador-de-electronica-en-la-cota.html It's an explanation on what kind of modern condenser you need for your bike, and how to place it on a 348 Montesa. Quote Link to comment Share on other sites More sharing options...
lbhbul Posted January 27, 2015 Report Share Posted January 27, 2015 For what it's worth I have used with great success for many years on any points ignition encountered, comes from most auto supply house's; Ford 302 ci/5 liter from 60/70's era, condenser mounted @ coil mount under tank. GOOD GROUND REQUIRED. Larry Quote Link to comment Share on other sites More sharing options...
bigshineybike Posted January 27, 2015 Report Share Posted January 27, 2015 (edited) I use one from a lucas 25d distributor. This is as fitted to most 1275 a series engines minis Mg midgets Morris minor etc. If it helps ask for a condenser for a 1970 Mg midget with 1275 engine. There are lots of alternatives but that worked for me. This type has a suitable tag to screw it to the frame with. rember you need to make good contact with the bare metal of the frame. Edited January 27, 2015 by bigshineybike 1 Quote Link to comment Share on other sites More sharing options...
hughandjen Posted January 29, 2015 Author Report Share Posted January 29, 2015 Thanks guys got one Going to fit it under the tank near the coil and fit a kill switch at the same time Quote Link to comment Share on other sites More sharing options...
