nigel dabster Posted February 24, 2015 Report Share Posted February 24, 2015 You'll spend even less if theyre not available............ 1 Quote Link to comment Share on other sites More sharing options...
telecat Posted February 24, 2015 Report Share Posted February 24, 2015 (edited) You take a chance whichever unless you have a Montesa. And then you pay though the nose. Recent events at Gas Gas and OSSA prove that. As it stands the Jotagas is liked by Chris and will be staying being supplemented by a whichever new bike Chris likes most in the summer, New JGas, TRS or Vertigo. These makes are basically backed by individuals which because of the nature of the market seems the best way to go at the moment. Edited February 24, 2015 by telecat 1 Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted February 25, 2015 Report Share Posted February 25, 2015 I think most spares are available for most makes, just surprised vital parts arent for jtg. Quote Link to comment Share on other sites More sharing options...
john.b Posted February 25, 2015 Report Share Posted February 25, 2015 The parts situation, is this correct or just keyboard rumours? Very interested as ordered a new bike and last thing I would want is not to be able to get spares if I needed them! Quote Link to comment Share on other sites More sharing options...
gasgas249uk Posted February 25, 2015 Report Share Posted February 25, 2015 Ive never had a problem getting anything. One guy i know couldnt get a rose joint for the top of the Olle shock ......but didnt contact Olle.....and couldnt work out that its a item available at bearing stockists......so just moaned. Theyre a tiny factory so there's going to be delays on some parts.Its obvious. Lets face it ...for most people we trundle around sections and dont give the bikes a hard time at all. I dont worry about the slight chance ill not be able to get a part that im not going to break in any case . Thats daft. Quote Link to comment Share on other sites More sharing options...
huski Posted February 25, 2015 Report Share Posted February 25, 2015 What parts are allegedly unavailable? Quote Link to comment Share on other sites More sharing options...
telecat Posted February 25, 2015 Report Share Posted February 25, 2015 (edited) I think that if there is a "problem" it's that no dealers carry stock. You can get the parts direct and Jitsie seem to be supplying now as well. My "local" guy seems well stocked but it would depend on how many bikes are about in your area as to what is carried. General parts like fork seals and brake parts are common so they are not a problem. Going to many Gas Gas and Beta Dealers and they have stock of the parts they know "go" and they will need to service the bikes. At dealers that carry the new marques they have to "guess". Edited February 25, 2015 by telecat Quote Link to comment Share on other sites More sharing options...
jackm Posted February 25, 2015 Report Share Posted February 25, 2015 Just a note on the oil ratio, I recently bought my son a Beta Evo 125 2014, the dealer said to run it at 75:1 and that my Jotagas 300 2014 would also be fine on this ratio so as not to confuse fuel cans. I can tell you that the Jotagas does not like 75:1 at all and I was having to clear her throat all the time like a motocrosser, so I would suggest reading the manual and staying with a good fully synthetic oil at 100:1, I went back to this and the Jotagas runs perfectly again. Quote Link to comment Share on other sites More sharing options...
peterh Posted February 25, 2015 Report Share Posted February 25, 2015 I run 100:1 synthetic (GRO) with no problems and having seen the oil collection around the piston skirt and crank after idling and pottering at trials like revs, I was amazed at the amount of oil that lined everything. I am down under in Oz and have not had a problem with parts, so I suspect much of it depends on your dealer not the factory or suppliers to the factory (given the similarity in common parts used across similar marques). Ride and Enjoy. Quote Link to comment Share on other sites More sharing options...
evo boy Posted March 18, 2015 Author Report Share Posted March 18, 2015 Hello All. Just a quick bit of advice needed. Has anyone had a rattle sounds engine but goes away when the clutch is pulled?? Is it normal and what spark plug would you recommend running. Thanks Quote Link to comment Share on other sites More sharing options...
telecat Posted March 18, 2015 Report Share Posted March 18, 2015 (edited) Yep that's normal for this "type" of engine/gearbox. There are only the Original and a "V" grooved plug that fit the JGas I'll look up the number tonight. The Original is a BPMR6A with the grooved been a BPMR6Y I think. Some prefer the Champion RCJ8Y. It's a stumpy plug compared to others and needs a different spanner to get it in and out. We run about 1mm gap as it runs a bit rough at any less. Edited March 18, 2015 by telecat Quote Link to comment Share on other sites More sharing options...
evo boy Posted March 18, 2015 Author Report Share Posted March 18, 2015 Thanks telecat that's put my mind at rest. Which plug do you run? Then I'll set mine up the same and see how it feels. Thanks Quote Link to comment Share on other sites More sharing options...
telecat Posted March 19, 2015 Report Share Posted March 19, 2015 (edited) We run the V groove version. I was going to check the type but had a mare last night with a flat and foam inflater just not working. one and a half hours for recovery and I still have to source another car tyre! I will see what I can do to make sure the V groove number is correct. The engine is like the Gas Gas with a Similar gearbox which is why you get a "rattle" when the clutch/gears are not engaged. Edited March 19, 2015 by telecat Quote Link to comment Share on other sites More sharing options...
