brigalow Posted February 11, 2015 Report Share Posted February 11, 2015 Can anybody help me out with oil type & quantity for gearbox/clutch on a cota 172 76 model? Quote Link to comment Share on other sites More sharing options...
kingscorpion Posted February 11, 2015 Report Share Posted February 11, 2015 SAE 10W30. 31,5 GB fl oz (900 cc.) 1 Quote Link to comment Share on other sites More sharing options...
brigalow Posted February 11, 2015 Author Report Share Posted February 11, 2015 Thanks Kingscorpion they're not separate as on the 247's? Quote Link to comment Share on other sites More sharing options...
kingscorpion Posted February 11, 2015 Report Share Posted February 11, 2015 Nope. Quote Link to comment Share on other sites More sharing options...
talbotvanman Posted June 20, 2015 Report Share Posted June 20, 2015 Just asked about this elsewhere mine is a Cota 200 I gathered the oil was common to both as there is only one drain plug ! I have a good supply of 5/30 would you be ok with using this kingscorpion ? Anyway thanks for confirming my thought about there only being one oil. Quote Link to comment Share on other sites More sharing options...
kingscorpion Posted June 25, 2015 Report Share Posted June 25, 2015 Sorry for the delay. I've been missing for some time. 5/30 can be an option. But it depends on the oil additives. Some of them will produce a slippery clutch. I've always used Motul Transoil 10w30. It has a specific formula for older engines. Quote Link to comment Share on other sites More sharing options...
talbotvanman Posted June 25, 2015 Report Share Posted June 25, 2015 Making a note of Motul Transoil Ive decided to replace crankshaft oil seals the engine is a bit smokey since using 5w/30 mainly cause there was hardly any oil in the motor !! So will revert to 10w/30 Thanks. Quote Link to comment Share on other sites More sharing options...
