dmc2028372 Posted February 13, 2015 Report Share Posted February 13, 2015 Morning all.. Ive bought a fantic 240 with a 245 engine in it.. Its a tidy job, but the engine doesn't run as crisply from the bottom and I suspect its down to the sh...y oko carb on it. Ive had an oko on my other 240 and never had much success with it so went back to a new dellorto, 100% better.. Any suggestions as to what to try.. Do I go back to the proper dellorto for that engine (PHBH26?) What exactly is the correct carb for it? There are so many slighty different versions of the 26 carb? Or do I go down the keihin route? Thanks Quote Link to comment Share on other sites More sharing options...
fastbelly Posted February 13, 2015 Report Share Posted February 13, 2015 I thought the OKO was supposed to be a better carb for the Fantics, I have one on my 240 but not ridden it yet, I will Sunday. Mine also has a later engine but is still 212 cc. Is yours a 249? Quote Link to comment Share on other sites More sharing options...
dmc2028372 Posted February 13, 2015 Author Report Share Posted February 13, 2015 The 245 engine is a 212cc. It's a type fm363. I had a oko on the other 240 engined 240 and it was pants too. I think If I could find the correct dellorto for this engine I'd go for that Quote Link to comment Share on other sites More sharing options...
axulsuv Posted February 13, 2015 Report Share Posted February 13, 2015 I've had a OKO on my 240 with a K&N air filter for a few years now ... And I wouldn't even consider changing it ... Glenn Quote Link to comment Share on other sites More sharing options...
grib Posted February 13, 2015 Report Share Posted February 13, 2015 The original carb on a 245 is a PHBH 26 CS, with an air pilot screw as opposed a fuel plot screw. £146.98 from Eurocarb. Quote Link to comment Share on other sites More sharing options...
dmc2028372 Posted February 13, 2015 Author Report Share Posted February 13, 2015 Thanks for your replies. Auxsluv, what's the jetting on your oko? Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 14, 2015 Report Share Posted February 14, 2015 On 2/13/2015 at 10:31 PM, grib said: The original carb on a 245 is a PHBH 26 CS, with an air pilot screw as opposed a fuel plot screw. £146.98 from Eurocarb. Air screw Dellorto carbs of that era weren't very good, go for a petrol screw type. Quote Link to comment Share on other sites More sharing options...
dmc2028372 Posted February 14, 2015 Author Report Share Posted February 14, 2015 So what would be the model number of that type carb? Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 14, 2015 Report Share Posted February 14, 2015 PHBH26BS is what I ordered,(tickover and petrol screw on left when sitting on bike) about £115 . Quote Link to comment Share on other sites More sharing options...
dmc2028372 Posted February 14, 2015 Author Report Share Posted February 14, 2015 Thanks for that B40. What bike did you run that carb on? Quote Link to comment Share on other sites More sharing options...
axulsuv Posted February 14, 2015 Report Share Posted February 14, 2015 On 2/13/2015 at 11:28 PM, dmc2028372 said: Thanks for your replies. Auxsluv, what's the jetting on your oko? Mine was set up by a chap in Eastleigh and shipped to me here in the states , And except for a float valve with microscopic imperfections (that I replaced with a kehin one ) , I've never had a issue with it . Crisp and quite powerful from idle to WFO ... As to the jetting , I don't know , never needed to play with it .(if it ain't broke , don't fix it !!!) I do know the idle circuit in the carb has been modified and to what extent I do not know as I've never had a standard OKO to compare it too . And like everything else these days there are Chinese copies of the Taiwan made OKO's that are almost identical in looks alone , not quality ... My 240 starts 1st or 2nd kick everytime cold , and 1/2 a kick hot , Idles so low and stable most folks think it's gonna stall , and will tractor up from idle without any complaints , allows me to not use my clutch as much as I probably should . She's real smooth till about 2/3 throttle then the lovely 240 pro comes on pipe and you best be pointed correctly ... Ryan Young always grins more than normal when he plays on her . Glenn Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 14, 2015 Report Share Posted February 14, 2015 On 2/14/2015 at 1:49 PM, dmc2028372 said: Thanks for that B40. What bike did you run that carb on? Rotax 240 motor so jetting probably no relevant, but I have all the info if your interested. Only chimed in to save you wasting time with an air screw carb. Quote Link to comment Share on other sites More sharing options...
dmc2028372 Posted February 15, 2015 Author Report Share Posted February 15, 2015 That would be great. Am keen to get a good dellorto back on the bike. Any thought's on a keihin flat side? Quote Link to comment Share on other sites More sharing options...
fastbelly Posted February 15, 2015 Report Share Posted February 15, 2015 Hi, I got to ride my 240 today in a trial. It runs very well. Starts so easy, runs nice and clean, no stalls, nice smooth power, very tractable. Jetting on my OKO is P 35, M100. However the tank is a standard one and I filled it most of the way to the top, I was surprised to have it go on reserve in a 4 lap x 10 section trial on a relatively small ground although it was muddy. Dunno why it drinks so much fuel. I dont recall my 300 using that much back in the days when I could still drink and shag on the same night. 2 Quote Link to comment Share on other sites More sharing options...
