technowaldo Posted February 13, 2015 Report Share Posted February 13, 2015 Got a 200 minarelli and cant get the carburation right and am toying with spending the money and getting a flatside oko for it .just wondered if it is a worthwhile upgrade or not Quote Link to comment Share on other sites More sharing options...
twinshockdude Posted February 13, 2015 Report Share Posted February 13, 2015 I`ve had recent experience of oko carbs on a ty175 - total piece of s... ! sorry but it was rubbish,i sent it back for refund 1 Quote Link to comment Share on other sites More sharing options...
andy m Posted February 13, 2015 Report Share Posted February 13, 2015 I had issues with a 200 a while ago, firstly how old is your cdi? I changed both coils (there is an upgrade) and then fitted an OKO , it was a worthwhile upgrade, started and ran like a watch and performed well. Quote Link to comment Share on other sites More sharing options...
turbo Posted February 13, 2015 Report Share Posted February 13, 2015 I have one on my 156 and it is superb . Quote Link to comment Share on other sites More sharing options...
axulsuv Posted February 13, 2015 Report Share Posted February 13, 2015 They just need to be set up properly , by someone with the knowledge to do so ... Glenn Quote Link to comment Share on other sites More sharing options...
furse Posted February 13, 2015 Report Share Posted February 13, 2015 Personally a new dellorto carb would be a better purchase, may get away with new slide and jets but the body will be worn also. And as mentioned above electrics need to be spot on Quote Link to comment Share on other sites More sharing options...
steve fracy Posted February 14, 2015 Report Share Posted February 14, 2015 My 200 was awful almost unrideable with the stock Dellorto and put a OKO on and transformed the bike. I was very impressed~! Quote Link to comment Share on other sites More sharing options...
eddie1 Posted February 14, 2015 Report Share Posted February 14, 2015 After restoring my Fantic it initially ran fine but quickly developed a carb fault. I changed a couple of jets but concluded that I needed a new carb. I figured that as vitually the same type of delloro carb was fitted to recent gas gas bikes then there could not be a lot wrong with the actual carb just the fact that the one on the bike was 35 years old. I fitted a new dellorto which was jetted and had the correct slide for the Fantic. It run great straight away and still going strong 2 years later. I've no experience of the OKO but I would suggest it is a replacement rather than an upgrade nothing wrong with the dellorto unless it is worn. Note Dellortos can be bought cheap on E bay but the standard jets and slide are not suitable for the 200. i know dellorto uk and inmotion will supply correctly set up carbs but cost a little more. Quote Link to comment Share on other sites More sharing options...
fantic240motor Posted February 14, 2015 Report Share Posted February 14, 2015 Personally I'd buy another stock Dellorto. I did the same with both my 240's, the old carbs were simply worn out and the inlet rubbers hard. I think there are two issues here that often get mixed up. Does the bike run okay on it's original set up or does it need improving? I'm happy with the stock Dellorto but if you think that it is in some way inadequate then go with the OKO. Quote Link to comment Share on other sites More sharing options...
fastbelly Posted February 14, 2015 Report Share Posted February 14, 2015 Thats cleared that up then. lol Quote Link to comment Share on other sites More sharing options...
technowaldo Posted February 14, 2015 Author Report Share Posted February 14, 2015 Cheers guys the engines been all rebuilt including all new ignition and I tried a brand new dellarotto from a friends bike and it did perk it up a bit but it still wasnt how it should be .think ill bite the bullet and try a oko.ill let you know how I get on Quote Link to comment Share on other sites More sharing options...
scorpa250 Posted February 14, 2015 Report Share Posted February 14, 2015 I`ve had recent experience of oko carbs on a ty175 - total piece of s... ! sorry but it was rubbish,i sent it back for refund I had a go at getting a Oko carb dialled in for my Whitehawk 200 after 2 new carbs and countless hours no joy . Fitted a flat slide dellorto and one hour later Its perfect. A little expensive but so are Two Oko carbs and jet sets !! Quote Link to comment Share on other sites More sharing options...
