Fork Leg Pinch Bolts
gaby
Have an '01 290. One of the two pinch bolts at the bottom of the fork broke in half. I have been riding with just one bolt doing the "pinching". Can I get away with this or am I risking more damage to the fork leg?
I'd definitely fix it. You're asking for trouble running it like that.
If the uneven stress cracks the clamp, you'll really be bummed out.
I would punch the broken bolt as deeply as possible to keep the bit from slipping and make some sort of pilot to go through the outer hole to keep the bit centered. You could use hardwood dowel or aluminum rod.. Put a piece as tightly as possible in the hole and drill through the center. This will keep your bit centered as you drill the bolt.
Try left-handed bits.
Most of the time they walk the bolt right out as you drill.
I'm in the process of replacing the lower leg on a 99 at this time due to a crack in the same spot. Take my word for it; even if you have to bring it to a machine shop to have it done properly, it will be worth it in the long run.
And remember, they
A tip a fitter gave me at work years ago for the removel of broken studs.
Centre pop the stud first, if it's a 8mm stud your dealing with start off with a small bit....say 4mm...now heres the key..... only drill into the stud 5mm, then use a 7.5mm bit and just go down to the 5mm, then go back to the 4mm bit and repeat the process untill you reach the end of the stud.
This way you dont never go off center, when you finished drilling get a pair of narrow plaires and just pull at the thread, it should just pull out like a spring :wacko:
Worked for me twice so far ;)
A couple of well placed dabs of weld will give you a nice handle to grab and pull that "stud" out with, and if it does not work, you are no worse off than when you started. If you get walking just a bit with a drill, it will much prefer the soft aluminum to the steel of that bolt.
What do you think Charlie????
For me personally, the magnetic attraction of the aluminum is directly proportional to the cost of the piece and whether I own it or the Army does B)
My drill wants to wander into a $200 aluminum hub, much quicker than into a $60,000 rotor blade for some reason!
As my sister said after she got married, "I just assumed that you went out into any mans garage and there was a big red toolbox and 5 welders lined up!"
  • 3 months later...
Hey, I finally got around to removing that pesky bolt! Charlie, the dowel rod worked like a charm. I then used an extractor to back out the remainder of the bolt. I chased the threads for good measure...Back in business!!!
Thanks everybody for the tips :wacko:
