Coolant Leaking Out Of Breather
oylee1
Even if the fan appears to be working, you might find the thermo-switch has become intermittent. It's happened to me twice. Unexplained coolant smell and visible coolant down on the bash plate. Fan appeared to be working (was coming on and off as usual). Obviously it wasn't always coming on as required and a week or two later it stopped coming on.
Replaced the thermo-switch (again) and it's all fine. I also installed an extra earth wire and bullet connector under the tank so I can easily by-pass the switch if it fails again.
Chris.
