itstommmm Posted February 20, 2015 Report Share Posted February 20, 2015 (edited) anyone got one? are they good on power etc how much better would a 2006 beta rev 3 125 be Edited February 20, 2015 by itstommmm Quote Link to comment Share on other sites More sharing options...
jfc Posted February 20, 2015 Report Share Posted February 20, 2015 (edited) I don't know to much about the Sherco, but the 2006 Rev is near the end of the Rev model production ( 2008 was the the last Rev to be made) so the Rev will be near the top of its evolution and was a good bike. They all have there problems, if you opt for the beta you will need to find out if the clutch casing has been changed as the original casing tended to corrode due to them being magnesium, the replacements are aluminium so if it's been done no more problems, if it has not been done then you will have to budget around the £100.00 mark to replace it. Hope that helps a little sorry I can not advise on the sherco. Edited February 20, 2015 by jfc Quote Link to comment Share on other sites More sharing options...
itstommmm Posted February 20, 2015 Author Report Share Posted February 20, 2015 I don't know to much about the Sherco, but the 2006 Rev is near the end of the Rev model production ( 2008 was the the last Rev to be made) so the Rev will be near the top of its evolution and was a good bike. They all have there problems, if you opt for the beta you will need to find out if the clutch casing has been changed as the original casing tended to corrode due to them being magnesium, the replacements are aluminium so if it's been done no more problems, if it has not been done then you will have to budget around the £100.00 mark to replace it. Hope that helps a little sorry I can not advise on the sherco. thanks for response mate. definatley going for a gagas or beta, heard some bad things about sherco 1 Quote Link to comment Share on other sites More sharing options...
copemech Posted February 21, 2015 Report Share Posted February 21, 2015 Oh no! I have heard horrible things about tham bikes! Quote Link to comment Share on other sites More sharing options...
itstommmm Posted February 21, 2015 Author Report Share Posted February 21, 2015 Oh no! I have heard horrible things about tham bikes! Really? What? Quote Link to comment Share on other sites More sharing options...
dadof2 Posted February 21, 2015 Report Share Posted February 21, 2015 The Beta is 2 years newer and at this time 125cc development was quite rapid. The Beta has quite a bit more power right at the bottom end, not that it has a lot but the Sherco has virtually none. Nothing much wrong with Sherco, what have you heard? Beta may have case corrosion issue and Gasgas prone to gearbox problems. Quote Link to comment Share on other sites More sharing options...
