kevpg Posted February 21, 2015 Report Share Posted February 21, 2015 Hi, I have just fitted a Michelin Comp front trials tyre to my AJP Trail bike, for the March Hare event next weekend. I tried 10psi on the first ride and wobbled round the first corner like a wounded buffalo, it was awful. I am now going to try 14psi in the hope that the road manners improve, this seems much to hard for trail use however. Is this handling trait normal with this tyre? Cheers Kev Quote Link to comment Share on other sites More sharing options...
iridebikes Posted February 21, 2015 Report Share Posted February 21, 2015 On our bikes we run 4/4.5 psi in our front tyres and have no problems? Quote Link to comment Share on other sites More sharing options...
kevpg Posted February 21, 2015 Author Report Share Posted February 21, 2015 I run my Montesa MH fitted with an IRC at 4/5 psi with no issues also but on the trail bike the handling is just awful, even at low speeds. No idea why? Quote Link to comment Share on other sites More sharing options...
kwackerdave1 Posted February 21, 2015 Report Share Posted February 21, 2015 Kev, I've been riding LDT for 15/16 years and always have trials pressure for sections. I use 7lbs or 8 lbs if rocky going for the front. Rear I use 5 or 6 lbs. bike is a Honda SL230 so a similar weight. The March Hare is nearly 1/2 off road so you will not need higher pressures. Have a good day, missing it for the first time in 15 years. Gutted. . Dave. Quote Link to comment Share on other sites More sharing options...
toetoe Posted February 21, 2015 Report Share Posted February 21, 2015 i went from a irc to a Michelin comp rear tyre and it took some getting used to, the walls of the tyre are much stronger than the irc so now i run it with just 2 psi in it and it's perfect, i would go for 5 to start with and just play around with it, most of the people who i asked about the michelin don't bother to use a pressure gauge, if it feels good and grips well then thats it, your done. Quote Link to comment Share on other sites More sharing options...
kwackerdave1 Posted February 21, 2015 Report Share Posted February 21, 2015 Toe he is on trail bike on a road event so Definately no low pressures. Police would not be happy. My Honda runs on IRC occasionally Dunlop and the bike has 19000 mks on the clock. All done in trials. Have managed to win 1 or 2 events in that time. Keep speed down on the Tarmac as tyres can lose centre blocks. Quote Link to comment Share on other sites More sharing options...
axulsuv Posted February 21, 2015 Report Share Posted February 21, 2015 Kevpg , might be a silly ? , but are you sure the bead is set completely even and correct ? easy to miss and will give real funky feel ... Have fun in your ride , Glenn Quote Link to comment Share on other sites More sharing options...
totalshell Posted February 21, 2015 Report Share Posted February 21, 2015 lose centre blocks....?? i ve never done it never seen it.. run 4 in the back 6 in the front irc have very soft walls and it feels like your riding a flat tyre, michelin tyre of choice.. no copper will stop you on them pressures.. Quote Link to comment Share on other sites More sharing options...
steve_earle Posted February 22, 2015 Report Share Posted February 22, 2015 Front pressure varies depending on individuals. I always run michelin. Now your'e all gonna think I'm crazy or making this up, But I run around 10psi if really muddy and 15+ in the dry. This is in trial competition not on trails or anything. I forgot to let the front tyre down once in a wet trial and found the bike was riding great, I didn't realize till after when I went to blow both tyres back up again. Experiment with pressues, dont be a lost sheep and follow the heard, Find whats best for you. 1 Quote Link to comment Share on other sites More sharing options...
kevpg Posted February 22, 2015 Author Report Share Posted February 22, 2015 Thanks for all the replies chaps, I checked the seating and all is fine then had a nother run out today on the road and some trails. I have settled at 14psi which is ok on the road, the front no longer tries to tuck in all the time, and acceptable on the trails. I am just surprised that a trials tyre handles worse than a half worn knobly. Thanks again. Kev Quote Link to comment Share on other sites More sharing options...
