jml Posted February 28, 2015 Report Share Posted February 28, 2015 (edited) Hey guys, Quick question about the exhaust packing in my 2010 Beta EVO 125 2T. I've noticed that my bike compared to other bikes of similar age is a lot louder. Most other bikes I can not only hear the exhaust but also a bit of engine noise too, there exhaust almost seems to "putt" where mine seems to "pang". Mine is a more of a harsh sound and it sounds like the packing is not absorbing much of the sound at all, I popped the end cap off the bike to discover a bunch of grime and goop inside the lower silence itself and similar but a lot less inside the end cap. The goop in the exhaust is blocking all of the holes in the metal baffle. I've read that if you get the exhaust hot enough some of this can burn off, but this looks really goopy, what's the best option in my case? Go for a hard ride? New silencer time? Throw some petrol down it? Photos inside the exhaust system (scroll down for all the photos, click to zoom): http://imgur.com/a/eyRKH Edit: I'm running 98 octane with Motul 800 2T oil, 72:1 (same as the previous owner) Thanks Edited February 28, 2015 by jml Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted February 28, 2015 Report Share Posted February 28, 2015 (edited) No matter how hard you ride it a trials bike is eventually going to need the perforated tube cleaned and the packing replaced. It's an easy job and, now you've got this far, obvious how it's done. Just don't put the new packing in too tightly. I don't see blocked holes in the photos, it all looks very clean. Edited February 28, 2015 by 2stroke4stroke Quote Link to comment Share on other sites More sharing options...
richfr Posted February 28, 2015 Report Share Posted February 28, 2015 (edited) The center section can be burned off as the only way to open it is to cut then re weld (if its the same as a Rev3). I used a blow lamp hang it upright when it is hot enough it will burn the oil off on its own but do it outside and preferably without anybody around. Mine burned for over an hour I just had to apply a little more heat from time to time. It weighs about half what it did. I also did the front pipe but wasn't much in that but the carbon fell off easily after getting it hot. Edited February 28, 2015 by richfr Quote Link to comment Share on other sites More sharing options...
dadof2 Posted February 28, 2015 Report Share Posted February 28, 2015 Oven cleaner and pressure wash works pretty well. Centre section does have to be cut apart. Lack of centre section packing is often why and older bike never quite runs as "softly" as a new one. Quote Link to comment Share on other sites More sharing options...
dabba Posted February 28, 2015 Report Share Posted February 28, 2015 Do exactly as richfr suggests, I've done it many times on a 125 Evo. I also use the blowtorch on the front pipe, as there's a large chamber which gets clogged up. Usually burns for ages. The front pipe will turn a light golden colour, but you can use steel wool to bring it back to silver. You'll notice a huge difference in the noise and power output Quote Link to comment Share on other sites More sharing options...
jml Posted March 1, 2015 Author Report Share Posted March 1, 2015 You'll notice a huge difference in the noise and power output What type of difference did you notice in the noise from the exhaust after doing this? Quote Link to comment Share on other sites More sharing options...
dabba Posted March 1, 2015 Report Share Posted March 1, 2015 Your bike will sound quite loud and raspy at the moment because the silencer internals are clogged and not absorbing the exhaust pulses. When you've cleaned the whole system out and re-packed the tail pipe, it'll sound much quieter. 1 Quote Link to comment Share on other sites More sharing options...
