boner Posted March 1, 2015 Report Share Posted March 1, 2015 Guys, just got my 2011 290 back up and running. She starts on the choke nicely, and idles well off choke. However, I've just tried to pick the idle up a bit on the carb but neither the idle screw nor the air mix screw make any difference to the idle. Any ideas? Thanks Boner Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted March 1, 2015 Report Share Posted March 1, 2015 must be a blockage in the carb or jets Quote Link to comment Share on other sites More sharing options...
b40rt Posted March 1, 2015 Report Share Posted March 1, 2015 Air leak ? Quote Link to comment Share on other sites More sharing options...
boner Posted March 1, 2015 Author Report Share Posted March 1, 2015 Vacuum test done. No problems. Did notice that the air mix screw was weeping, and therefore potentially drawing in air. Any ideas how I could seal / rectify this? Quote Link to comment Share on other sites More sharing options...
huski Posted March 1, 2015 Report Share Posted March 1, 2015 A few turns of plumbers ptfe tape will seal it Quote Link to comment Share on other sites More sharing options...
0007 Posted March 1, 2015 Report Share Posted March 1, 2015 It's pretty much impossible for the idle screw to have no effect, it's mechanical and lifts the slide And I have never seen an air screw leak, it's drawing air How would you even know? Quote Link to comment Share on other sites More sharing options...
longlegscanbeuseful Posted March 2, 2015 Report Share Posted March 2, 2015 I have seen this before once when trying to tweek a friends carb. He had the throttle cable too tight so that the slide was not sitting on the idle screw. The air/mixture screw was also so badly adjusted that small changes had no effect. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted March 3, 2015 Report Share Posted March 3, 2015 do the jets have rubbers on? should they? Quote Link to comment Share on other sites More sharing options...
copemech Posted March 4, 2015 Report Share Posted March 4, 2015 do the jets have rubbers on? should they? Jeez, REALLY? Quote Link to comment Share on other sites More sharing options...
