Air Filter Reccomendations
tyrefryer
My 350 AJS currently has just a mesh covered intake on the 376 monobloc filter and I have been wondering if it might be an idea to fit a proper air filter to save wear and damage to the engine.
If so which would be better, a chrome pancake with paper filter like this:
http://www.ebay.co.uk/itm/321657925837?_trksid=p2055119.m1438.l2648&ssPageName=STRK%3AMEBIDX%3AIT
Or a K&N type cone filter attached to an adapter liker this:
http://www.ebay.co.uk/itm/261504367267?_trksid=p2055119.m1438.l2648&ssPageName=STRK%3AMEBIDX%3AIT
and
http://www.ebay.co.uk/itm/251859967712?_trksid=p2055119.m1438.l2648&ssPageName=STRK%3AMEBIDX%3AIT
Any comments and advice would be greatly appreciated, thanks.
OK my advice is fabricate a proper airbox from alloy and use a filter foam off a modern bike that are readily available. I use TY250R and the cage but Scorpa Sherco etc are fine. Personally i wouldnt touch the cone type foam or K&N type and am astounded that people mention reducing wear on the engine they scrimp on the air filter to save pennies but as they say round these parts "theres nowt so funny as folk"
Hi,
Purely out of interest Hugh Viney - who was the most prolific winner of important trials on his works AJS never had an air filter fitted, just a piece of old inner tube which created a relatively mud-free space from just in front of the carburettor to the rear mudguard. But think about it - the mesh, foam, K&N-type filters are ALL filtering fine dust particles. How many of the trials that you ride in are going to be in a dust or sand storm - desert racing maybe - classic British mud-plug, you've got to be joking.
I only ever had aluminium air boxes on my Ajays, Matchless, BSAs and Ariels, with air entry in through the base - and that meant I could fine tune my carburation on bikes DESIGNED to operate that way.
Complicated air filters start to really suffer when you drop a bike in a stream, pond or river section - but the simplest form of air box will quickly drain...........
Food for thought?
The paper filters don't like getting wet in my experience.
I use one of these:
http://www.ebay.co.uk/itm/AIR-FILTER-POLINI-VARIOUS-SIZES-32-37-46mm-STRAIGHT-INLET-WITH-WATERPROOF-COVER-/311082987884?pt=LH_DefaultDomain_3&hash=item486dfdb16c
Being foam you oil them like a modern bike with sticky air filter oil, it's amazing how dirty the oil is when you wash it off with petrol.
There are other exposed foam filters that work well and are cheaper, but on the Ariel the filter is right under the back corner of the tank and water was running off straight onto the filter. I've had no problems with the covered filter.
