Beta Techno Fork Seals
simonty
Hi Simonty:
I cant remember which forks the 97 techno came with but I think they are Paioli... Ryan Young has a section on fork seal replacement for the Sherco with Paioli forks that might be helpful to you, here is the link
http://www.shercousa.com/pdfs/sherco_fork_...placement-1.pdf
You might want to confim the oil capacity for the Beta since I am sure the amounts are different than the Sherco, my 2004 Rev3 takes 370cc in the right and 350cc in the left. If your seals are leaking just a small amount you might try tearing off about an 5-6 cm of 35mmm film, carefully inserting the film between the fork and the seal and going around the seal to clear any dirt that could be causing the leak. Sometimes that is all the problem is and not necessary to change out seals. :(
Good luck
T
  • 2 weeks later...
