Sherco Leaking Coolant
markmark
My bike started leaking coolant today from a little hole in the casing just wondering if anyone could shed some light into what is broke so I can get on and fix it the bike is a 2011 250
Here is the hole it defiantly looks like it should be there but don't no what it is
Some early Shercos had the impeller shaft machined from too soft a material and the seal wore grooves, causing leakage as lineaway says. A new, harder shaft was supplied under some warranty applications (I know, I had one, but it was a long time ago, 2001/2 model, I think).
The kit was new seals, bearings and a shaft and it was priced at @ £25, I think, would depend on the age of your bike
Edited by heavydabber
