Bultaco Clutch Nut
millerme
hi guys
tried to change the main seal on the bully this eve ,used a air impact gun got the crank nut off but no luck on the clutch nut
seam to be on very tight any ideas would be gratefully appreciated on the removal
The clutch hub is very difficult to hold, you will probably need to make/buy holding device probably Inmotion or E Bay,
you can sometimes hold the hub carefully with heavy gloves & using air impact get them loose.
A tool can be made from non eared clutch plate with a suitable handle welded welded to it.
Good Luck
Larry
