Parellel Or Taper Yokes?
trialsrfun
The alloy billet fork yokes that are sold by a number of people are usually available with steering stem parallel to the fork tubes or run out of usually around 1.5°
I have basic knowledge of how trail is calculated but so many people have varied opinion on this so if you have tried both types what did you find, which option seemed the better?
Personally i felt the difference more by fitting 360mm rear shocks instead of 340mm ones. I know that is a different thing but just to highlight you will hav to be very sensitive to be able to tell the difference. On a related subject the 1.5 degree yokes did allow me to drop the forks 10 mm through the yokes as with them fitted the mudguard didnt foul the exhaust on full compression :popcorn:
  • Like 3
