198A Lighting
tomtom385
Help,
I am in the process of road registering my 198 and want to wire in the stop light. i connected to the red wire from the stator, but when i press the brake the stop light comes on but the engine cuts out. i am guessing that the yellow or red wires are from the lighting coil. not getting any voltage from the yellow. My haynes manual only hints at the lighting circuit, can any one point me in the right direction.
Hi you need a resistor (8) in the circuits between the switch and the stop- and tail light, otherwise it won't work.
You can too use a regulator instead, which should have 6V and 45W.
The original resistor (looks crude) is not available anymore:
  • Like 2
Bondy,
Nothing wrong with "good old hand signals" But i am guessing that at least 50% of the car driving public would not know the slowing down hand signal, can see it now, hmmmmmm why is that geezer trying to fly with 1 arm flapping.
Fare comment i did think about that After i posted it thinking about it you would be safer with at least a stop light if nothing else don't know where you would stand with the MOT may have to have headlight also. :stupid:
  • 3 weeks later...
