Starts Then Dies
furse
Hoping someone can help me on this?
My fantic has developed a problem!
It will start ok, run then die like the kill button is pressed, some times it will run for a few seconds other times a few minutes
Disconnected kill switch completely
Check earth and all connections, good
Cleaned carb with airline all good,
Stator was rewound after the new year
Spark is good,
Replaced plug, cap and HT lead
Top coil is 12 month old dans tyoe,
Fault started after a couple of sections of trial, it was running great 5 weeks earlier on the last outing.
I had a similar problem yesterday on a bike that I rode the previous weekend that ran great. It would not start and when it did, ran a short time. Turned out the seat for the needle had come loose. I am not saying, that is your problem. You need to make sure it is getting fuel. Vent good, petcock good, Floats good, needle and seat. All carb vents clear. You get what I mean?
