dean_dabs Posted March 25, 2015 Report Share Posted March 25, 2015 Works well for a ill while, then the torsion spring seems to unwind & kick starter won't return to the top. Suggestions? Dean@learntoride.org Quote Link to comment Share on other sites More sharing options...
lineaway Posted March 26, 2015 Report Share Posted March 26, 2015 There has never been a problem with the kick starter other than stripping the splines on the shaft. I would assume you have worn parts or missing a part. Quote Link to comment Share on other sites More sharing options...
helm Posted March 26, 2015 Report Share Posted March 26, 2015 Hi had similer problems check that the locating recess in the crankcase for the spring has not worn,i was able to reshape mine with a dremal if you have the haynes manual page 47 shows the kickstart assembly part 9 is a small circlip one side is flat this needs to be towards the spring guide,overwise they can fail is the spring locating properly in the shaft? can,t think of anything else cheersq helm Quote Link to comment Share on other sites More sharing options...
dean_dabs Posted March 26, 2015 Author Report Share Posted March 26, 2015 Thanks for the good words guys. Shop manual ordered! Dean in Tennessee Quote Link to comment Share on other sites More sharing options...
