itstommmm Posted March 26, 2015 Report Share Posted March 26, 2015 Have read on many posts on this site that automatic transmission fluid is best for beta rev 3. Would this kind be ok? http://m.ebay.co.uk/itm/Triple-QX-ATF-Dexron-III-5-Litre-5L-Automatic-Transmission-Fluid-DII-/290994733693 Quote Link to comment Share on other sites More sharing options...
mrturtle Posted March 26, 2015 Report Share Posted March 26, 2015 yes if your going to try it dexron 3 spec is the one to get. i run it in my evo and ktm 300 and yes the take up is a little sharper but i found less clutch drag cold or hot on both machines Quote Link to comment Share on other sites More sharing options...
dadof2 Posted March 26, 2015 Report Share Posted March 26, 2015 You may well find Dexron III ATF gives too sharp clutch take up. Typically at 90 to 100 degrees C (The temperature of your engine; D III viscosity is 7 cSt 10w-40 viscosity is 15 cSt 75w gear oil viscosity is 9 cSt A 10w-40 or 5w-40 oil designed for combined motorcycle engine and transmission will probably give the best all round performance. Something like Putoline light gear oil is also good. ATF is not recommended by Beta and it is designed for hydraulic systems and clutches that work in a very different way to those found in trials bikes. 2 Quote Link to comment Share on other sites More sharing options...
lineaway Posted March 27, 2015 Report Share Posted March 27, 2015 I ran dex3 in every year of Techno`s and most Rev3`s. I preffered it, and so did most riders. If you don`t mind clutch drag, use a good all around oil. Change often as it is cheap. 2 Quote Link to comment Share on other sites More sharing options...
goudrons Posted March 27, 2015 Report Share Posted March 27, 2015 Gear oil and ATF are cheap enough to experiment with, see which suits you the most. Having used ATF a few times and I'm not a fan, it gives a far too grabby clutch for me. I guess it could be great if you ride like that, but I'm a bit old school and a clutch should feel progressive. I've found Putoline Nano Trans works for me, once warmed up I don't find it dragging too much and the feel of the clutch action appears much smoother. 1 Quote Link to comment Share on other sites More sharing options...
podracer Posted March 27, 2015 Report Share Posted March 27, 2015 You may well find Dexron III ATF gives too sharp clutch take up. Typically at 90 to 100 degrees C (The temperature of your engine; D III viscosity is 7 cSt 10w-40 viscosity is 15 cSt 75w gear oil viscosity is 9 cSt A 10w-40 or 5w-40 oil designed for combined motorcycle engine and transmission will probably give the best all round performance. Something like Putoline light gear oil is also good. ATF is not recommended by Beta and it is designed for hydraulic systems and clutches that work in a very different way to those found in trials bikes. Hi, Im Using Dexron 6... Recomended from the old fellows who ride Betas here... Is this any better than Dexron 3 ? do you now the viscosity difference from them ? Quote Link to comment Share on other sites More sharing options...
guys Posted March 27, 2015 Report Share Posted March 27, 2015 Light gear oil 75W, from Putoline GRO or Elf is made for the job and the GRO oil for instance, is recommended by GasGas. Very little drag and smooth clutch. I wouldn't recommend choosing an oil just because it's cheap. The oils might be cheap enough to experiment with, but your gearbox isn't. I'm not against ATF oil but get the right type from the first time. Experimenting with to much different oils could turn out very bad. 1 Quote Link to comment Share on other sites More sharing options...
