billyt Posted April 13, 2015 Report Share Posted April 13, 2015 Where is the front fork pre-load sag adjustment on a 2013 TXT Pro 280 ? Thanks guys Quote Link to comment Share on other sites More sharing options...
sirdabalot Posted April 13, 2015 Report Share Posted April 13, 2015 Fork with the drilled red ring at the top. The fork cap nut turns. Clockwise for more spring pre-load. It's a bit stiff to turn and will only screw in or out till it reaches its end stop. Quote Link to comment Share on other sites More sharing options...
billyt Posted April 13, 2015 Author Report Share Posted April 13, 2015 There is a red ring on both forks. One has a C on it the other a R on it. It guess C is for compression and R is for rebound. I dont see anything for pre load. There are red rings on both sides. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted April 13, 2015 Report Share Posted April 13, 2015 You cannot set the preload, only by putting shims/spacers on top of the springs. Quote Link to comment Share on other sites More sharing options...
sirdabalot Posted April 14, 2015 Report Share Posted April 14, 2015 Error on my part, I thought the 2013 fork tops were the same as the '14 + '15 Racing models. Quote Link to comment Share on other sites More sharing options...
