hoggyf Posted April 14, 2015 Report Share Posted April 14, 2015 Now even though I've done this before I'm struggling with this - I changed my fork seals last night and first off used 370cc of oil in the right leg but there was far too much to get the top nut back on. I pulled some out and went with 60mm down from the top of the leg when compressed, with the damper rod fully compressed, I could now get the nut back onto the damper rod and the top nut into the stanchion but..... if I do this with the stanchion pulled up it locks the fork up and if I do it with the leg compressed then it vacuums the leg and pulls it back down?????? I pumped the damper loads of times assuming it was air trapped but nothing was showing so I'm obviously making some kind of rookie mistake but what am I missing?? Gave up in the end, threw the toys out the pram and went inside Quote Link to comment Share on other sites More sharing options...
