big stu Posted April 14, 2015 Report Share Posted April 14, 2015 (edited) The black wire for the kill switch on my cdi is broken off is there any other way to fit a kill switch without replacing the whole CDI unit Edited April 14, 2015 by big stu Quote Link to comment Share on other sites More sharing options...
tony27 Posted April 14, 2015 Report Share Posted April 14, 2015 If it's broken off at the CDI unit then you will have to replace the unit, hard to remember if where the wires come out is plastic or resin, if it's resin it may be possible to chip it away enough to get a new wire soldered on & covered back over with araldite or similar. Could be worth trying as the worst that could happen would be you need a new unit Quote Link to comment Share on other sites More sharing options...
copemech Posted April 15, 2015 Report Share Posted April 15, 2015 Might try tapping it into the red wire, not much to lose here sounds like. Quote Link to comment Share on other sites More sharing options...
