techno94 Posted September 10, 2005 Report Share Posted September 10, 2005 Went to a trial with Lanarkshire club and tryed to start my bike and my left hand crankcase split . Does any one know why this would happen. Quote Link to comment Share on other sites More sharing options...
rev3guy Posted September 15, 2005 Report Share Posted September 15, 2005 Techno, some of the early Beta's had a problem with the gear on the starter shaft riding up an splitting the case. This was usually associated with a backfire which caused the motor to reverse and the gear to ride up. Part of the problem was traced to electronics and water getting into the system. Although many folks will say that the problem was licked by 1998, I did have the same problem on a 99 Techno 250. If you decide to fix you will need to replace both the cases since they are a matched set. Good luck and hope it goes well. Rgds Tony Quote Link to comment Share on other sites More sharing options...
techno94 Posted September 17, 2005 Author Report Share Posted September 17, 2005 I have just bought a rebuilt second hand bottom end from John Lampkin, ex Dougie. Quote Link to comment Share on other sites More sharing options...
