trevor lucey Posted April 21, 2015 Report Share Posted April 21, 2015 Hi I have a 2008 4rt it is my second 4rt and love the bike. I have the upgraded the spring as I am 5ft 10 and 13 stone. In the last six weeks I have replaced the gear lever, gear lever shaft and the rear brake lever twice. I never had this problem with my last 2005 4rt. The bike does not look to be any lower then any other 4rt and while I am riding harder sections the levers seem to be getting caught on every rock I ride past even outside the sections where I have ridden my old 4rt with no problem. Has anyone else had this issue? Thanks Trevor Quote Link to comment Share on other sites More sharing options...
guys Posted April 21, 2015 Report Share Posted April 21, 2015 I weigh even more, also have the Jitsie + 10% spring, and don't have your problem. Quote Link to comment Share on other sites More sharing options...
the addict Posted April 21, 2015 Report Share Posted April 21, 2015 Ride height is wrong I'd of thought, I'm having this problem so I'm thinking of getting a stiffer spring for my ever increasing 14 stone frame. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted April 22, 2015 Report Share Posted April 22, 2015 Check your suspension plates are installed correct way 2 Quote Link to comment Share on other sites More sharing options...
perce Posted April 22, 2015 Report Share Posted April 22, 2015 On 4/22/2015 at 3:46 PM, jimmyl said: Check your suspension plates are installed correct way Yes, you can put it together the wrong way round but it's very noticeable, the ride ride height is considerably lower. 1 Quote Link to comment Share on other sites More sharing options...
the addict Posted April 22, 2015 Report Share Posted April 22, 2015 (edited) On 4/22/2015 at 4:26 PM, perce said: Yes, you can put it together the wrong way round but it's very noticeable, the ride ride height is considerably lower. Plates are correct lads thanks, in my case the lowering of the ride height seems to be directly proportional to me quitting smoking six months ago on the same day I got the bike, the longer I keep off the tabs the closer the bike seems to get to the ground. Edited April 22, 2015 by the addict 2 Quote Link to comment Share on other sites More sharing options...
jrsunt Posted April 22, 2015 Report Share Posted April 22, 2015 Get back on the tabs, it'll save you a fortune with the amount your spending on brake pedals and gear levers!! 1 Quote Link to comment Share on other sites More sharing options...
the addict Posted April 22, 2015 Report Share Posted April 22, 2015 (edited) On 4/22/2015 at 7:10 PM, jrsunt said: Get back on the tabs, it'll save you a fortune with the amount your spending on brake pedals and gear levers!! Dr. Sunter lol. Edited April 22, 2015 by the addict Quote Link to comment Share on other sites More sharing options...
shedracer Posted April 23, 2015 Report Share Posted April 23, 2015 On 4/22/2015 at 5:16 PM, the addict said: Plates are correct lads thanks, in my case the lowering of the ride height seems to be directly proportional to me quitting smoking six months ago on the same day I got the bike, the longer I keep off the tabs the closer the bike seems to get to the ground. Stay off the tabs and go on the "Titanium diet", you won't be able to afford to eat and the weight will just drop off yourself and the bike. ;-) 2 Quote Link to comment Share on other sites More sharing options...
